Yes
ClemBert
02-04-2005 05:17:36
I have a 110 gallon sprayer with cluster nozzle I bought from Tractor Supply (link below). I use it to spray my 13 acre pasture. It works well but as others have stated you have to consider the wind factor more than if using a boom sprayer. Thats because the cluster nozzle will sit 36" to 48" above the ground in order to get maximum throw of the spray. This gives the wind more opportunity to catch the spray. I just make sure I spray when the wind is 5mph or less. The boom sprayers will get a lot closer to the ground but you always have to consider the wind. Even with a boom sprayer you don't want to spray on a windy day. The biggest problem with a boom sprayer is getting it hung up on a tree, fence, or other object in your pasture.
