sprayers
HaySam
02-03-2005 06:51:57
Has anyone ever used a cluster nozzle to spray pasture ? how does it compare to a boom?
ClemBert
02-04-2005 05:17:36
 Yes in reply to HaySam, 02-03-2005 06:51:57
I have a 110 gallon sprayer with cluster nozzle I bought from Tractor Supply (link below). I use it to spray my 13 acre pasture. It works well but as others have stated you have to consider the wind factor more than if using a boom sprayer. Thats because the cluster nozzle will sit 36" to 48" above the ground in order to get maximum throw of the spray. This gives the wind more opportunity to catch the spray. I just make sure I spray when the wind is 5mph or less. The boom sprayers will get a lot closer to the ground but you always have to consider the wind. Even with a boom sprayer you don't want to spray on a windy day. The biggest problem with a boom sprayer is getting it hung up on a tree, fence, or other object in your pasture.
JMS/MN
02-03-2005 07:56:41
 Re: sprayers in reply to HaySam, 02-03-2005 06:51:57
Works ok as long as there is little or no wind.
jc
02-03-2005 18:45:24
 Re: sprayers in reply to JMS/MN, 02-03-2005 07:56:41
You got that right. No booms to snag the fence though.
