Other contents of N-Viro Soil (NVS)
ClemBert
01-24-2008 06:54:11
The cost DELIVERED is $25/ton.
This is what is advertised:
Nitrogen 20 lbs/ton
Phosphorous 10/lbs/ton
Potassium 10 lbs/ton
Magnesium 8 lbs/ton
Sulfer 20 lbs/ton
Calcium 490 lbs/ton
Micronutrients
Alternative to having to add Dolomite/Lime because this material contains lime dust from Fly-Ash. Thus, it is a low cost alternative to having to add Dolomite. It has half the liming capacity of pure limestone.
The solids content is 65% (I assume there is a certain percent of water per ton) with the balance of the material not listed at the top being organic matter (500 lbs/ton)
Last, it has a moisture rentention of 45-75%. NVS has the consistency of high organic soil which is probably good down here in Florida since our soils tend to be VERY sandy.
