Device results
onefarmer
12-27-2007 22:38:32
For the HP 315 camera: I can find XP drivers for it. But no Vista. Also is no longer supported by HP.
For the HP ScanJet 3300C: I found drivers that say they will work with XP.
For the DeskJet 842C printer: Drivers are availible upto Vista from HP.
For the Deskjet 820cse printer: Drivers are availible upto Vista from HP.
For the Lexmark printer: Drivers are availible for most upto XP and only the newer ones for Vista
55 50
12-28-2007 11:08:34
 Re: Device results in reply to onefarmer, 12-27-2007 22:38:32
Argh!!! Don"t believe everything HP says about drivers! I have first hand experience with them and my old scanner (Scanjet 3300C). I went from Windows ME to XP and the Scanjet would not work after downloading drivers. After repeated emails to HP "troubleshooters" with no success, they finally said we'll have a software guru call you and he got my scanner to work AFTER 45 MINUTES on the phone. One day later the scanner quit again. I went through the steps the guru gave me (thank goodness I wrote down his instructions as we talked) and got scanner working again. It quit again! (You see the pattern?) After a few times through this, I said enough and went and bought a new scanner compatible to XP. New scanner (definitely not an HP!) has worked fine ever since.
onefarmer
12-28-2007 15:21:47
 Re: Device results in reply to 55 50, 12-28-2007 11:08:34
I did find one site making that complaint about the scanner. But it was the only one I found, so I wrote it off. But if you have had problems also then I will believe it. I went to a Lexmark all in one that can be used as a sheet feed or flatbed
