Looks bad from here
Larry T
08-27-2007 16:38:50
After looking at them from the given angles, I cant believe that you can pull it at all if you could get it in the ground. Looks like the rear sheer hooked a root or something. They are pulling against each other which would either bury them or cause them to just skate over the top. Make sure that both frames are parallel with each other , and that when you set them down, they sit level and both hit at the same time. You can use the top link and right side arm adjuster to do some of this, but get it straightened out before you try to use both together. Larry T
