Pancho, Sorry for the hijacked thread
onefarmer
08-22-2007 11:17:52
Pancho,
Keep up up to date on your issue. We'll keep at for you.
If you find the problem let us know. May help one of us in the future
El Toro
08-22-2007 15:54:07
 Re: Pancho, Sorry for the hijacked thread in reply to onefarmer, 08-22-2007 11:17:52
Hi Jon, That engine shouldn't stall even if he runs the cylinders's piston all the way out and holds the control valve in the extend position. That's when I found the problem on my splitter when it wouldn't downshift into the second stage. The pressure wasn't high enough and I tried to adjust the pressure higher and it never changed. When I installed the 4 bolts in the pump
it almost pegged the pressure gauge. Very close tolerances on those pumps. Northern Hydraulics gave me another pump, but it was the same until I called the pump company. Need to follow those instructions. Hal
onefarmer
08-23-2007 06:18:57
 Re: Pancho, Sorry for the hijacked thread in reply to El Toro, 08-22-2007 15:54:07
Hi Hal,
I've never used a splitter with a pump before. So no experience. I always hooked to a tractor. I would think there would be a pressure relief, or something, so the engine wouldn't stall. Thats why I was thinking the engine had an issue. Like it would stall as it makes the transition from part throttle, to wide open. Like a carbed car with a bad accelarator pump.
If I'm thinking correct you needed all four bolts in the pump mount or the pump case would twist just enough to bind the valve so the pump wouldn't kick down to the 2nd stage?
