First 1000
MF Poor
06-23-2007 10:04:26
third party image
A picture is worth a thousand words. First pic is a general over-view of stabilizers installed on a Massey Ferguson 150. Very simular to your 35.
smalltimesnd
06-23-2007 10:42:21
 Re: First 1000 in reply to MF Poor, 06-23-2007 10:04:26
Questions? With the clarity of those pictures, it doesn't leave room for questions! Wonderful! After your illustrated pamphlet, I discovered that there are brackets already in place. They're different and look more heavy duty (cast), but same principle. And although I think I don't have the original fenders (mine are squared with a big rollbar attached), the bolts are there for the mounting. That was great. Thank you. Now for a big piece of cardboard to lay on and some tools....
MF Poor
06-23-2007 10:07:38
 Re: second 1000 in reply to MF Poor, 06-23-2007 10:04:26
third party image
This picture shows the bracket. It mounts with the fender bolts. There is some forward/rearward adjustment via the slotted holes. Don't tighten the bolts until both sides are installed and in proper alignment.
MF Poor
06-23-2007 10:10:35
 Re: third 1000 in reply to MF Poor, 06-23-2007 10:07:38
third party image
Here is another view of the angle brackets. Note the multiple holes available to attach pins. Use the set of holes that directly align with pivot point of lower links (draft arms) so they pivot with each other.
MF Poor
06-23-2007 10:18:52
 Re: fifth 1000 in reply to MF Poor, 06-23-2007 10:10:35
third party image
Final shot. One last picture of the angle bracket. With everything in place, and fender bolts snug BUT NOT TIGHT, move the hitch up and down to let everything "settle" into a natural fit. Then tighten fender bolts. Make sure they're REAL tight or the stabilizer bars will apply enough pressure to make the fender bolts move a bit, loosening them.
Hope this helps. Any questions?
