Tedder
Hay DR
06-05-2007 06:50:43
third party image
Both tedding right after mowing and waiting until the next morning are both acceptable. The ground moisture has allot to do with which one is best. You have to have dry ground to dry hay. If the ground is soggy wet under the hay you will have to dry the ground out first before the hay will totally cure.
You might want to look at the new Sitrex 5200H tedder.
