Tedder
NEIADan
06-04-2007 11:01:04
In our area we can't get 3 days to bale hay anymore. I mow with a Mac Don 5020 12ft haybine and I know a 9ft would be better at least for the 1st cutting. My question is would you spend the $6200 for a new Vermeer 4 basket tedder. If so when would you ted the hay. I have heard that some follow the mower within an hour of mowing, others wait until the next day. What is the right way to do this. I have been warned not to buy a lighter duty unit with the 12' cut. Thanks for any ideas.
kyhayman
06-11-2007 21:04:38
 Re: Tedder in reply to NEIADan, 06-04-2007 11:01:04
Most years I couldnt farm without a tedder. I normally run it from 4-24 hours after I mow. After that the hay is just too dry. As to money, 6200 is way too much. I gave 2800 for a 1 year old New Idea 2 years ago, metal has gone up but not that much.
This year has been the exception. 6/10ths of rain since May 9. I've used my tedder once. Mostly my problem is the hay is too dry, wants to follow the belts out of the baler when I start a roll. Cant even do any good at night, no dew for the last week.
Hay DR
06-05-2007 06:50:43
third party image
Both tedding right after mowing and waiting until the next morning are both acceptable. The ground moisture has allot to do with which one is best. You have to have dry ground to dry hay. If the ground is soggy wet under the hay you will have to dry the ground out first before the hay will totally cure.
You might want to look at the new Sitrex 5200H tedder.
backwoodsfarm
06-04-2007 16:40:10
Here in Maine, we only get two cuttings a year at best, and a tedder is an absolute must to get hay to dry as quick as possible. I put up around 8,000 square bales per year. If we cut with the haybine in the morning, we ted it out that afternoon. We then ted it again the next morning after the dew is gone, rake an hour or so later, let it dry some more and then bale. That's only if the weather has been hot, breezy and dry. Otherwise we just ted it again on the second day, then ted, rake and bale the third day. We usually use the tedder more than any piece of haying equipment because there is really no alternative unless your baling haylage. Most people here use Kuhn or New Holland, however, the cheaper Morra tedders are starting to show up, and I hear they are very good. Good luck!!
mtgummibear
06-05-2007 07:30:47
 Re: Tedder in reply to backwoodsfarm, 06-04-2007 16:40:10
First let me say I've never used a Tedder so I'm lookingn for information, but do you also "move" the hay that much if you're doing alfalfa?
I was always taught to do the mimimum "turning" on alfalfa to keep maximum leaf content. Is a tedder really really that much more gentle than a side delivery rake for example?
It just sounds like an awful lot of turning before you bale it. My background is midwest and west and it used to be that many hay farmers just let it dry in the windrow without turning (if the weather is good) or at the most just turn the windrow once.
I'm currently in the south and I see Tedders are very popular on the Bermuda grass hay most people put up around here.
Basically just curious since I've never personally used a Tedder.
Luke S
06-04-2007 13:05:02
No, I wouldn't spend $6200 on a Vermeer, but I would spend $3000-$3500 on one of the imported ones, they hold up plenty good, I had good luck out of the ones I have had. I now have a JD and it is no better than the cheap ones.
