Apples vs oranges
Tx Jim
02-21-2007 04:01:45
Hugh,I agree with your comparison of an offset disk to a tandem disk with 20 in blades as being "apples to oranges". Soil types are different in different parts of the world and large diameter blades will not plow axle deep here in North Texas in most types of soils. During summer here no plow will penetrate the soil not even a chisel plow. I guess soils in Canada are easier to till!!! BTW what width and blade spacing was that Bush Hog,80 blade tandem disk that you pulled with 100 hp tractor? Must have been a 28/30 footer or larger. Tx Jim
Hugh Mackay
02-21-2007 04:59:15
 Re: Apples vs oranges in reply to Tx Jim, 02-21-2007 04:01:45
Jim: As I recall the blade spacing were about 7"-8". Been awhile so I don't have the exact figure. The whole disk was slightly over 21 feet, depending on angle of gangs.
Bear in mind the the 4" square frame was tubing. My offset disk had 26" blades, spaced 10" or 12" but it also had 4" square frame, but this one was solid steel, that adds a lot of weight. I don't doubt there is a lot of difference between my sandy loan and you Texas soil. I've been on discussions long enough to hear just how hard Texas soil is. In our soil my offset with 26" blades would got axle deep much quicker than the tandem I had with 20" blades. I liked the offset for putting down corn stover, it chopped it better, yet left stalk material close to surface, thus it broke down faster. Basically I used it as primary tillage. In spring it was one pass with tandem disk followed by cultivator with leveling plank and crumbler.
I quite agree that big disk blades will not penetrate without added weight, however it took more steel in that frame to withstand those big blades.
In knew a guy with an 80 blade 20" blade offset. He pulled it with a 4630. I drove it once before I bought my tandem. I really couldn't see a whole lot of difference in pulling that or my 80 blade 20" blade tandem. One could say his 4630 had more hp than my 1066, however I loaned him my 1066 once for forage harvester. He told me it made his Deere look bad. Believe me the Deere dealer got going over on that one, I know because he asked me if my 1066 was turned up.
Tx Jim
02-21-2007 05:30:51
 Do the math in reply to Hugh Mackay, 02-21-2007 04:59:15
Hugh a 21 ft tandem,7"-8" spacing would have around 60 blades not 80. If you don't believe me do the math. A JD 1635 plowing tandem will not go any where near spool deep here with 24 in cone cut-out blades and they have a very high pound/blade ratio but I feel confident that your Bush Hog tandem will go to spools here. As far as your 4630/1066 story goes this all depends on condition of engines,hp settings and traction. Next well be talking about the 4500 sq.bale/day one man hay operation. Later,Jim
Hugh MacKay
02-21-2007 10:59:24
 Re: Do the math in reply to Tx Jim, 02-21-2007 05:30:51
Jim: As I read this, I never said 21', I said slightly over, however I did say exactly 80 blades. I guess that would depend how exact you want to get on slightly over 21'.
You don't give the specs on the JD 1635, thus I have no comment.
The 4630 and 1066 were as they came from factory, 4630 had about 400 hours and 1066 around 8,000 hours, and it was the Deere owner's opinion not mine. I had driven his tractor but never at max. pull. I never figured either one of our tractors were anywhere near max. pull on the disks we had. Both tractors had been bought new to run forage harvesters.
The 4500 bales per day was not a one man hay day, but rather about 15 to 18 men. Small square bales have never been about horsepower, just pure manpower.
Tx Jim
02-21-2007 12:03:43
 Re: Do the math in reply to Hugh MacKay, 02-21-2007 10:59:24
Hugh,I've never heard a 22' tandem with 80 blades.
You didn't give spec. on Bush Hog tandem,so I won't comment
You still haven't convinced me a near worn-out factory hp 1066 will out pull a factory hp 4630 in warranty !!!!! !!!!!
pcy1066
02-21-2007 14:22:10
 Re: Do the math in reply to Tx Jim, 02-21-2007 12:03:43
i will chime in here, i have owened at least 50 ih 1066 tractors and only 4 4630 jds on any given day any one of the 10s will have the 4630s for lunch, thats why we dont have them any more, i liked the 4630 cab but they all were addictid to starting fluid at 30 degrees, in the feild the 10s will run all day at 250 plus hp wfo, the jds wont i will take a 1066 over a 4630 any day
Hugh Mackay
02-21-2007 13:49:55
Jim: Do you comprehend 80 blade 20" blades? Seems quite clear to me. You on the other hand didn't even suggest blade size or number of disks on that Deere.
No one said anything about any tractor out pulling the other. The Deere owner knowing full well his 4630 being rated 20+ hp more than the 1066, after using my 1066 on his forage harvester, said, "It makes my Deere look bad". He didn't say it ran away with the harvester, he didn't even say it did as well as the 4630. I forget the exact ratings but that 4630 would have been rated around 150 hp. It was always my opinion that he the owner of the Deere was somewhat disappointed with his tractor. By the way that 1066 was turning 150+ the day it was new, it was turning 150+ at 4,000 hours as it was at 8,000 hours, and that was as it came from the factory.
This discussion started out comparing offset to tandem disk, that my friend was the question, in case you hadn't noticed.
Tx Jim
02-21-2007 15:35:24
 size of blades in reply to Hugh Mackay, 02-21-2007 13:49:55
Hugh,yes I comprehend 80 blades 20" in dia.
JD 1635 tandem as stated has 24" blades,it has 24 blades(6 per shaft) As for as the two tractors you implied that your 1066 was factory hp as was the JD,so who can't comprehend????? ???
Neither of us is going to convince the other "so stick me with a fork like a baked potatoe" I'm done
Hugh MacKay
02-21-2007 16:56:38
 Re: size of blades in reply to Tx Jim, 02-21-2007 15:35:24
You know Jim, I've felt exactly the same way last 2-3 rounds. What in hell were we discussing?
