In my opinion
bh
12-14-2006 05:50:44
We probably try to run the boots too far. They are sort of difficult to get a good look at. Ours will wear out on the side facing the trench (opposite of the blade)and allow loose dirt into the boot with the seed. If you take a boot off and look at it from the side you'll easily see the wear pattern. The post about replacing the blades at 17" when the bevel is gone is the rule that we go by. A worn blade makes the boot wear more also. Be sure and check your the bushings where the opener's pivot on the bars. We found about 10 of ours wearing into the arm last year. That couldn't have been good for the alignment of the unit either.
