Which Spool Valve for 1955 Ford 600
FreeRanger
10-16-2006 07:06:08
I have a 1955 Ford 600 model 640. I would like to be able to lift my New Holland haybine with hydraulics. Currently I am using a racheting top link which is time consumming and hard work.
How the heck is do I determine which hydraulic spool kit fits my tractor? What other parts do I need? Should I also look into rebuilding the internal pump BEFORE I purchase the spool valve? The 3pt is working OK at this time but it is a very old tractor. I do use it to "farm" not for show.
Help on buying the right stuff needed!
Leroy
10-17-2006 05:45:57
 Re: Which Spool Valve for 1955 Ford 600 in reply to FreeRanger, 10-16-2006 07:06:08
You need the valve made just for that ford tractor. It bolts where there is a small plate on the right front corner of the lift cover housing, would be actuall under the front corner of the seat. They are avaible with or without detent to hold the valve automaticaly or manualy to end of stroke and also avaible in 1 lever single spool models for 1 cylinder or 2 spool for 2 cylinders. You are looking in the neighborhood of $300 + dollars for that kit.
Tx Jim
10-17-2006 04:19:40
You need a valve that bolts directly to top of rockshaft made specifically for Ford tractor remote hyd's. This site sells them. All you need to do is a search "Tractor Parts". Tx Jim
Skycarp
10-16-2006 07:29:02
FreeRanger,
Not want to show disrespect to you, I will be as direct as possible. You have redirected my original request for specific information to a much broader request for information on your own problems. Now those who offer information and suggestions to this thread will have to sort out which request for information they are responding to.
Please start your own thread.
FreeRanger
10-16-2006 09:01:14
 Say what? in reply to Skycarp, 10-16-2006 07:29:02
I didn't know you own the thread?
I purposely asked the question because I was trying to the other person's attention. He seem to know what he is talking about.
You seem to know about hydraulic valves for Ford tractors. Answer the question, how did you determine what to buy?
I don't know why anyone would have trouble with the two questions. They are related. If you take a look at any of the long thread responses you would see people build upon the original questions ALL the TIME. That's why it is call a forum.....
J Schwiebert
10-16-2006 19:04:59
 Re: Say what? in reply to FreeRanger, 10-16-2006 09:01:14
I am not a Ford wiss kid and you may want to ask on the Ford form. There is a place you tap in I remember that. After that I can give you advice. Just remember it is free. I have a friend that has a Ford of about that vintage and size. I can look at it when I get a chance. But nothing against you if it stays dry, we have fall harvest to do. J.
