Hydraulic mid-mount setup
Fighting suburb
09-08-2006 05:17:49
The old road mower hydraulic setups will do what you want but they require a high volume hydro pump to run the drive motor and have a very unwieldy mounting system. The newer(that being a relative term) belt driven (pitman-less) rearmount sickles should be able to handle a 45* downslope but I have never run one so I am not sure about how far down one will actually work.
The mid-mount hydraulic setup on mine will drop down a little more than 45* but it could conceivably work at 90* down. The limiting factor is the geometry of the mount and the length of the raise cylinder. They are the trick for keeping ditch, stream, and pond banks clean.
