noise in 605 K
Hay DR
08-30-2006 07:49:40
We have had this scenario happen on a 605 K baler making a noise just like you say. The Air Gage was not accurate. We put a new air pressure gage on the baler and had only one color separation between the setting of the air & hydraulics, the noise went away. Before we did this we took the belts out and checked for a bad bearing and could not fine a bad bearing. You have to start at one end of the possible causes and check them all to fully isolate the problem. This may not fix you baler but it might be something you've not checked yet.
