Here's how
RickB
08-05-2006 14:28:42
As the needle yoke moves the first couple inches, the needle latch linkage allows the latch spring to pull the needle latch into the path of the plunger crank arm. The crank arm should have just passed by the latch when this happens. If the needle to plunger timing is correct, by the time the crank arm comes around to the needle latch again, the tie cycle is complete, the needle yoke and knotters are "home" and the latch has been pulled out of the path of the plunger crank arm. Check for a broken/missing needle latch spring and/or a siezed pivot on the needle latch itself.
