Copy of post !! #1
Punchie
02-10-2006 05:20:14
HI Doghouse
I talked to a number of full time farms in our area. They say 2500 would be tops. And farther more a NH 69 would have a good job of baling 1500 in one day let alone 4500 of any size. Most are beef and older Dairy men, they say the most any of them have done is 1000-1200 with a good crew and one baler. I have yet to talk to a family that sale hay for a living. I will this week and ask them what baler they are using, a couple of years old top of the line NH cost them some $$ . They do 30000 - 35000 bale of Timothy a year 1 st cutting him and his Dad. But they have top of the line equipment. They all said 500 in our area is a good number to make top grade 1st cutting. Per day, day after day after day. For any setup, one baler. That was my thinking.
Teddy
P.S. Posted late as to not feed this fire any more.
John17
02-10-2006 08:28:36
 Re: Copy of post !! #1 in reply to Punchie, 02-10-2006 05:20:14
Punchie, when you are talking about timothy hay and someone else is talking alfalfa or clover, believe me you are talking apples and oranges. It takes an awful lot of ground to make 100 bales of timothy, we would get almost 200 bales of alfalfa or clover in a little over an acre. There are a lot of differences in areas of the country. I have lived in many of them, and seen farming operations in a lot of different areas. The fact that you can not fathom that it could happen, does that mean that it cannot? I do not think so. When someone tells you something, LISTEN. Maybe what they are telling you is not completely acurate, but you may learn something from them. I can tell you, I put up a lot of hay behind a New Holland Super 69 baler, and to the point that was trying to be made, the limiting factor was LABOR! That was one fo the best balers of it's day for putting heavy hay through. It seemed you could not stop it. Take the point as it was presented, and move on. JohnG
Punchie
02-10-2006 05:24:01
 Re: Copy of post !! Answer #1 in reply to Punchie, 02-10-2006 05:20:14
Posted by Hugh MacKay on February 09, 2006 at 17:27:25 from (209.226.247.62):
In Reply to: Re: Baling Hay numbers . posted by Punchie on February 04, 2006 at 21:37:49:
Teddy: That is a cowardly way of doing it, but then what could one expect. Time you woke up and read the numbers, manufacturers rating on most of these balers was 15 ton per hour and in any bodys book that 100 ton per day. Most balers I've seen were better than the rating by the manufacturer.
sjh
02-11-2006 13:26:50
 Re: Copy of post !! Answer #1 in reply to Punchie, 02-10-2006 05:24:01
Lets see 100 ton / 15 ton per hour = 6.6 hours. There isn't any farmer in my area that only works 6.5 hr a day. More like 12 hrs a day doing hay. That would be 180 ton or 6000 bales @ 60lbs.
I worked with a guy whos father baled and put up 5000 bale of straw in one day.All by himself ever year.
