IT WORKS!
Rod in Smiths F
11-16-2005 15:36:53
Excellent advice, and I thank you.
The apron went on without much trouble, apart from the usual hassles with a come-along. Anticipating that it wouldn't let go when I wanted it to, I tied a loop of rope around the track on one end and hooked into the loop. Then I simply cut the rope to free the come-along.
I ended up using a lot of rope over the afternoon, as the front left idler was mis-alligned and it took two derailments before I was able to remedy the problem. Two 5/8" washers straightened the idler and the apron ran relatively smoothly after that. Further tests tomorrow.
I dumped a 5 gallon pail of old transmission/ hydraulic oil onto the bed and apron, so the machine isn't too pretty right now. I'll go back with clean hands and a camera tomorrow to make of the project what I can, as far as photos go.
JMS/MN
11-18-2005 11:10:56
 Re: IT WORKS! in reply to Rod in Smiths Falls, ON, , 11-16-2005 15:36:53
Glad to help you..... .and believe what paul said about hauling dirt. They do a fine job, but you cannot haul too much at once. Dirt, sand gravel, etc weighs about 65+ lbs per cubic foot. Manure is much lighter. Wood weighs less. Cubic yard of gravel is about 2800 lbs.
11-18-2005 16:10:32
 Re: IT WORKS! (PIC) in reply to JMS/MN, 11-18-2005 11:10:56
The first load went over the apron today -- planer shavings. I figured I'd work up gradually to heavier products as I learn about the adjustment of the apron.
I'll try to put up a picture of the project.
phil in nova scotia
11-17-2005 12:15:44
Hey Rod I just had to look up where smith falls,On. is seeing one of my other loves in kayakingand FALLS usually means FUN for me ,,,WOW I'm up your way every year to beachburg area ,got lots a good buddies up there ,,Bunch a crazy whitewater paddlers ,some of the best whitewater around is not to far from you ,,but I'm sure you've seen those crazies going with their lil plastic boats on top of their cars..Very beautiful farm country on the Ottawa valley ,,
phil in nova scotia
11-17-2005 10:30:08
11-17-2005 12:23:01
 Re: IT WORKS! in reply to phil in nova scotia, 11-17-2005 10:30:08
Phil:
Back in my salad years (before the knees got stiff) I used to run the spring races in an open 16' canoe. Good fun and survivable, as long as the canoe had enough displacement for its crew.
The sport has evolved a great deal since the seventies. A recent colleague was on the Olympic White Water Kayak team before teacher's college and the mishapen blob of plastic on his Honda didn't do much for my aesthetic sense, but apparently it works very well in the rough stuff.
If you are up this way in September of 2007, stop by my woodlot: it will be on the grounds of the International Plowing Match, held at Crosby, Ontario. Between now and then I'll be doing lots of tree-hugging to get ready for it.
Good talking to you,
Rod
