Firewood spreader project: tomorrow's the apron.
Rod in Smiths F
11-14-2005 18:22:16
It's all there except the apron. My welder friend replaced the front sprocket supports today by cutting out the fatigued metal on the 513 New Holland and welding in new plate. His milling machine? Cutting torch.
He's leaving the installation of the apron to me. He warned that I'll be jamming my fingers a lot before I have finished.
Any tricks to re-installing an apron on a spreader after a new floor? All Don told me was that the chains only bend one way.
paul
11-17-2005 13:41:52
 Re: Firewood spreader project: tomorrow's the apr in reply to Rod in Smiths Falls, ON, , 11-14-2005 18:22:16
Sounds like you got yourself a good deal there, got 'er working.
A little advise: Someday, the idea to haul dirt or gravel with it will occur to you. Easy to unload. Just only load it 1/2 full with these at the most. Ever. Any more, & it will bust. Dirt does not slide well at all, and way over-stresses the web & web drive, which was designed for wet slippery manure.
--->Paul
11-17-2005 18:09:27
 Re: Firewood spreader project: tomorrow's the apr in reply to paul, 11-17-2005 13:41:52
Half load of gravel, you say? I was thinking about it, I'll admit. Maybe I'll try six inches or a foot and work up.
First thing I'm going to try, though, will be a load of planer shavings.
Thanks for the heads-up.
BobMo
11-15-2005 16:43:43
I guess it won't be long before you can start that stacker or will that be the one that fixes dinner now?
11-15-2005 20:30:53
 Re: Firewood spreader project: tomorrow's the apr in reply to BobMo, 11-15-2005 16:43:43
Good question. 2' high piles of firewood don't do a lot of good. I could start a pile at the foot of a tall retaining wall but I don't know how well wood dries without wind getting at it. With an 8' drop unloading would be easy, though.
Gaby
11-15-2005 10:03:15
How about some pics when your done?
Jason, NW Ontario
11-16-2005 06:47:21
 Re: Firewood spreader project: tomorrow's the apr in reply to Gaby, 11-15-2005 10:03:15
Yes. I definitely want to see some pics after all is said and done!
JMS/MN
11-14-2005 20:18:13
Use a come-along to pull the ends together. With the tighteners all the way loose there should be just enough slack in the apron to get the chains together, and the come-along holds things in place while you work with it. Doesn't hurt to have one or two slats underneath the cable- depends how long your come-along is. Put it in the middle of the slats, on top of the deck. No need to work underneath.
11-16-2005 15:36:53
  IT WORKS! in reply to JMS/MN, 11-14-2005 20:18:13
Excellent advice, and I thank you.
The apron went on without much trouble, apart from the usual hassles with a come-along. Anticipating that it wouldn't let go when I wanted it to, I tied a loop of rope around the track on one end and hooked into the loop. Then I simply cut the rope to free the come-along.
I ended up using a lot of rope over the afternoon, as the front left idler was mis-alligned and it took two derailments before I was able to remedy the problem. Two 5/8" washers straightened the idler and the apron ran relatively smoothly after that. Further tests tomorrow.
I dumped a 5 gallon pail of old transmission/ hydraulic oil onto the bed and apron, so the machine isn't too pretty right now. I'll go back with clean hands and a camera tomorrow to make of the project what I can, as far as photos go.
JMS/MN
11-18-2005 11:10:56
 Re: IT WORKS! in reply to Rod in Smiths Falls, ON, , 11-16-2005 15:36:53
Glad to help you..... .and believe what paul said about hauling dirt. They do a fine job, but you cannot haul too much at once. Dirt, sand gravel, etc weighs about 65+ lbs per cubic foot. Manure is much lighter. Wood weighs less. Cubic yard of gravel is about 2800 lbs.
11-18-2005 16:10:32
 Re: IT WORKS! (PIC) in reply to JMS/MN, 11-18-2005 11:10:56
The first load went over the apron today -- planer shavings. I figured I'd work up gradually to heavier products as I learn about the adjustment of the apron.
I'll try to put up a picture of the project.
phil in nova scotia
11-17-2005 12:15:44
Hey Rod I just had to look up where smith falls,On. is seeing one of my other loves in kayakingand FALLS usually means FUN for me ,,,WOW I'm up your way every year to beachburg area ,got lots a good buddies up there ,,Bunch a crazy whitewater paddlers ,some of the best whitewater around is not to far from you ,,but I'm sure you've seen those crazies going with their lil plastic boats on top of their cars..Very beautiful farm country on the Ottawa valley ,,
phil in nova scotia
11-17-2005 10:30:08
11-17-2005 12:23:01
 Re: IT WORKS! in reply to phil in nova scotia, 11-17-2005 10:30:08
Phil:
Back in my salad years (before the knees got stiff) I used to run the spring races in an open 16' canoe. Good fun and survivable, as long as the canoe had enough displacement for its crew.
The sport has evolved a great deal since the seventies. A recent colleague was on the Olympic White Water Kayak team before teacher's college and the mishapen blob of plastic on his Honda didn't do much for my aesthetic sense, but apparently it works very well in the rough stuff.
If you are up this way in September of 2007, stop by my woodlot: it will be on the grounds of the International Plowing Match, held at Crosby, Ontario. Between now and then I'll be doing lots of tree-hugging to get ready for it.
Good talking to you,
Rod
