Re: IH 1420 combine--removing PTO gearbox--supporting engine?
zooeyhall
07-05-2020 09:01:05
Yes--it's the rear seal on the engine.
When (and if) I get the PTO unit off, I'm going to replace the seals on that also. Since it is off already.
I'm thinking I may place a block of wood or something under that RR corner of the engine to support it. Since the other three mounts are still in place, there shouldn't be that much weight on it when the gearbox is removed.
Matt from Oz
07-05-2020 15:12:48
 Re: IH 1420 combine--removing PTO gearbox--supporting engine? in reply to zooeyhall, 07-05-2020 09:01:05
Just be careful what part of the engine you support. Not looking at it now but the oil pan is only pressed metal if original. We replaced it with a cast one from a tractor, had trouble with that gasket leaking. Let us know how you go with it.
