Jerry
05-07-1999 20:56:01
Re: Re: rear main still stuck in reply to Jerry, 05-07-1999 20:09:28
I just got back to this page and noticed the other response. He's 100% right. If it's a lip seal, it's time to break apart tractor, but I figure it must be rope seal. I have pretty good luck to reinstall the rope seal. I take a piece of aluminum electric fence wire, thread it into one end of new seal, and tie it real tight. I then soak the new seal over night in clean motor oil, or if I don't have overnight . I rub it real good with GOJO hand cleaner, no pumice or grit in it. Then I take a flat screwdriver and the new seal under the engine. Thread the wire around the crankshaft, stick the screwdriver into the flywheel and start rolling over the engine, hold pressure on the wire, yep just keep pulling the wire and rolling the engine, be patient, it's gonna be irritating. Don't pull it through any more than you have to get the wire off it, be sure you don't pull it completely flush on the other side,leave a little sticking out both ends. Clean up the cap real good. Put in that half of the new seal, leave just a little of it sticking up too, don't cut it off flush.. Put white lithium grease on it or clean motor oil, clean the cap off real clean and dry on both ends. Just to the outside of each end of seal, dab just a trace of silicone, not enough to squeeze up against the crankshaft. Put the cap on. Get it all buttoned back up, now jump up there and fire that mother up. We need you in the field now.
