Re: 172 gas won’t start
petertay
05-22-2020 13:04:12
No moisture. Thanks for asking.
The coil is Echlin IC-9, 6V, oil filled. Doesn’t indicate internal resistor, but there is a resister up by the gauges with two white wires clipped to it. Cant trace the white wire from the coil, because it disappears into a wiring harness.
petertay
05-22-2020 15:17:52
 Re: 172 gas won’t start in reply to petertay, 05-22-2020 13:04:12
The wire from the + side of the coil does go to the resistor. So if I buy a new coil, would it be better to get a 6V or 12V?
Also, are points and condenser the same at 6 or 12 volts? —Peter
