Company Logo Shop Now
TractorLinks.com
172 gas won’t start
petertay
05-22-2020 09:39:05
This 4140 with 172 gas has started instantly in the 6 months I’ve owned it. Same this morning, except I backed it out of the shed and it quit.
1. The fuel bowl is full and clean
2. Pulling the drain under the carb shows good fuel flow
3. Points are clean and set properly
4. With dist cap off, can see the points sparking 5. Removed wires from coil and cleaned terminals
6. Pulled lead wire from distributor to watch for spark. (It is the kind of wire with no copper, some sort of black fiber)
7. Spark seems weak. I can barely see it in daylight
8. Pulled a wire from a spark plug to watch the spark. Didn’t see the spark but got a whale of a shock
9. I know better, but shot a bit of starter fluid into the air intake
Nothing has changed since it was used a few days ago. It has spark and fuel. Any ideas are much appreciated. —Peter
David G
05-22-2020 10:59:38
 Re: 172 gas won’t start in reply to petertay, 05-22-2020 09:39:05
Sparking points can indicate bad condenser.
petertay
05-22-2020 09:41:42
I should add that it has been converted to 12 volt, neg ground.
miner09
05-22-2020 10:56:03
 Re: 172 gas won’t start in reply to petertay, 05-22-2020 09:41:42
Does coil have internal resister? If not and no external your points maybe bad. Also is coil 12 volt?
petertay
05-22-2020 13:04:12
 Re: 172 gas won’t start in reply to miner09, 05-22-2020 10:56:03
No moisture. Thanks for asking.
The coil is Echlin IC-9, 6V, oil filled. Doesn’t indicate internal resistor, but there is a resister up by the gauges with two white wires clipped to it. Cant trace the white wire from the coil, because it disappears into a wiring harness.
petertay
05-22-2020 15:17:52
 Re: 172 gas won’t start in reply to petertay, 05-22-2020 13:04:12
The wire from the + side of the coil does go to the resistor. So if I buy a new coil, would it be better to get a 6V or 12V?
Also, are points and condenser the same at 6 or 12 volts? —Peter
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2020 Yesterday's Tractor Co.
