steve n carol
02-24-2008 08:11:32
Re: Ford 3000 hydraulic question in reply to Larry NCKS, 02-23-2008 14:12:19
Mathias NY said: (quoted from post at 15:12:19 02/23/08) The 3pt hitch on my 3000 will only lift about 200 lbs, 400 lbs if I rev the engine. The fluid was milky, so I changed it, no change in performance. Once the lift is raised, it will hold the weight overnight, so I don't think it is a rockshaft problem. Does this sound like a problem with the pump or the relief valve? Thanks for the help. |
Mathias, I am going to go "out on a limb" here. Perhaps to save you some labor, (at this point). I know just enough about this topic to be dangerious. (that was my disclaimer).
Without having to remove the lift cover, you can access a valve from the outside. I believe this is the relief valve. This valve is located in the lift cover. At the front. In front of the seat. Below any Hyd remote valves, (if equiped). If I recall correctly, it looks like a hex bolt head. You can remove this valve with ease, unless it is stuck. Look on your parts CD and print out the diagram take the diagram into the front room(where you are working on the tractor, I assume), and take this relief valve apart. ON MINE.... The valve check ball was hammered and so was the seat. As well as being put back together incorrectly. Since these are very, I mean VERY, expensive to replace w/new, I reassembled mine and use it like it is, Which is marginal (now). Which is MUCH better than it was. I also suspect that the intake screen (on mine) needs to be cleaned. I was going to replace this.....HA! PER THE PARTS MAN AT FORD.....$$537.00 FOR A %$#^*&%# FILTER! However, the steel tube came with it :D The parts man also told me that this filter is a 'screen' and can be cleaned! :D Since I could not remove this filter from the top, and don't want to split my tractor at this time. So, I will drain out the fluid (again) and backflush the intake line w/the drain plug removed. This is my plan anyway...
Please let us know how you fare w/ this...sl
