Re: 6 volt system
Phil (VA)
06-17-2003 12:06:33
I agree with Tim, but I think if your voltmeter across the battery terminals while the tractor is running shows approximately 7.2 volts, it probably is charging ok. As he said, 6 volts is not adequate. I'm guessing you don't have a meter. You can get a decent one for about $20. Get one that measures volts, amps, and ohms, and read the directions carefully. Most have batteries which go bad quickly if left on, and also a fuse which blows if you use it improperly.
