6 volt system
Chris
06-16-2003 21:41:04
Does anyone know how to tell if my charging system is working. I believe that I have a 641 with 6 volt system. I really am not sure if the generator is working. I am new to tractors so feel free to talk to me if I were a moron.
Phil (VA)
06-17-2003 12:06:33
 Re: 6 volt system in reply to Chris, 06-16-2003 21:41:04
I agree with Tim, but I think if your voltmeter across the battery terminals while the tractor is running shows approximately 7.2 volts, it probably is charging ok. As he said, 6 volts is not adequate. I'm guessing you don't have a meter. You can get a decent one for about $20. Get one that measures volts, amps, and ohms, and read the directions carefully. Most have batteries which go bad quickly if left on, and also a fuse which blows if you use it improperly.
Tim Dalrymple
06-17-2003 06:26:49
The easiest method is to remove the positive terminal while the tractor is running. The 641 is a positive ground system. If the tractor dies, the charging system is not working.
The correct method of testing the charging system requires a voltmeter. You should read approximately 8.4 volts dc across the battery when the tractor is running. If you read closer to 6 volts, your charging system is not working.
Hope this helps,
Tim D.
