Order Ford NAA Parts Online
Re: Jubilee Low Oil Pressure
zane
01-19-1999 17:21:26
I don't know about this particular model, but most engines equipped with oil filters also have a filter relief valve, set to open and bypass the filter when it becomes so clogged it impairs adequate circulation of oil. If this engine was so equipped and the device was working properly, I would think it would allow a better pressure.
Dan
01-19-1999 20:32:25
 Re: Re: Jubilee Low Oil Pressure in reply to zane, 01-19-1999 17:21:26
Yes sir, the Jubilee does have a bypass valve. On the Jubilee (with the original, early type oil filter) oil flows through the filter, into the hollow center bolt (which contains the bypass valve) and into the main oil gallery. If everything is working properly, the pressure at both ends of the tube is equal and the bypass valve within is closed. When the filter is clogged, pressure in the tube at the bottom of the valve is lower than the pressure at the top of the valve. When the pressure differential is approximately 7 psi the bypass valve opens. The open bypass valve allows unfiltered oil to flow into the main oil gallery under pump pressure.
There is not much to the bypass valve. Very low tech.
I am not saying that changing the oil filter wouldn't fix a low pressure situation. Under certain circumstances it might. With the later style, screw-on oil filters (the Jubilee can be retrofitted to accept the later style filters) the bypass valve is within the filter itself. If the early style oil filter with center bolt has been replaced with the later style screw on, replacing the oil filter would also replace the bypass valve. Replacing an oil filter with the early style center bolt does not affect the bypass valve, and a stuck valve/clogged filter may affect engine oil pressure.
'course, I could be wrong.
Dan
NAA60512
Pam
01-31-1999 09:38:12
 Re: Re: Re: Jubilee Low Oil Pressure in reply to Dan, 01-19-1999 20:32:25
I have a 1967 Mack tandem dump truck which I recently had overhauled and the oil pressure wont
get up above 40 is this ok? Any response will be
greatly appreciated.
