Order Ford 801 Parts Online
Re: ford 801 powermaster
Doug
04-15-2003 05:08:15
I had the same problem and what I found out was the gear inside transmission had the teeth worn down. I replaced the gear and it works fine now. It not hard to replace just take the slector gear w/cover off drain fluid take the 4 bolts off the output shaft and pull it stright out about 6 inchs once this is done you can take a flashlight and look into the bottom of the trans you have to take out a 9/16 inch bolt and washer being carefull not to drop it and then you can grab the gear and take it out, the gear cost about $200.00. Hope this helps
