Order Ford 801 Parts Online
Ford 801 powermaster
tim jones
04-13-2000 19:03:20
i have a ford 801 powermaster with a pto problem.you can be working and the pto will jump out of gear.any clues to fix it would be welcomed. THANK YOU Tim Jones
Doug
04-15-2003 05:08:15
 Re: ford 801 powermaster in reply to tim jones, 04-13-2000 19:03:20
I had the same problem and what I found out was the gear inside transmission had the teeth worn down. I replaced the gear and it works fine now. It not hard to replace just take the slector gear w/cover off drain fluid take the 4 bolts off the output shaft and pull it stright out about 6 inchs once this is done you can take a flashlight and look into the bottom of the trans you have to take out a 9/16 inch bolt and washer being carefull not to drop it and then you can grab the gear and take it out, the gear cost about $200.00. Hope this helps
JR. Means
04-18-2000 10:26:08
I can't help you with the pto problem but I have a question regarding the price of an 801. I have located one for sale and can't find much information about value. It is a 1958 model with good paint and rubber. Are these about the same value as the 8n and 9n Fords?
Thanks JR.
