Order Ford NAA Parts Online
Re: Help With NAA
John IA
03-15-2003 19:52:47
Ron,The serial number should be on the bell housing right by the starter. If it's an early jubilee instead of an NAA the serial number is on th e right side of the block. As far as the 12 volt system, some one has converted it. As the Naa's and Jubilee's were 6 volt systems. If you still have trouble finding the serial number on the left side of your computer screen You'll see a research and info click on serial numbers and it should tell you where it's located. John
