Re: Which way to go?
STUMP PULLER
02-02-2000 16:21:47
YOU WILL LIKE THAT 12V. IF YOU WANT TO KEEP IT SIMPLE YOU COULD READJUST YOUR REG TO CHARGE AT 12V.
twopop
02-03-2000 17:37:46
 Re: Re: Which way to go? in reply to STUMP PULLER, 02-02-2000 16:21:47
DOES THE 12V COIL YOU PUT ON HAVE A BUILT IN RESISTER IN IT OR DID YOU PUT AN IN LINE RESISTER ON YOU WILL NEED ONE OR THE OTHER OR YOU WILL BURN POINTS CONSTANTLY
moye
02-04-2000 10:48:43
 Re: Re: Re: Which way to go? in reply to twopop, 02-03-2000 17:37:46
it is simple to put 12v points and condensor in this tractor. while you are at it, change to a 12v delco alternator and get rid of the gen. and reg. that is there now. If you think you might wish to restore to origional one day and quit working the tractor, save all the 6v stuff to put back on it. Just my two cents worth. Moye
