Which way to go?
John C.(CA)
02-02-2000 16:05:46
Well got the 860 running today. After changing Points, dist cap, rotor battery leads, and pulling the Carb apart, all with no help. I resorted to getting a 12v Coil and 12v Battery, hooking up the battery, Neg ground and just a positive to the new coil and jump started to the starter, (had disconnected the Generator and Starter). The thing started rite up, So I am guessing that I had a bad 6v coil or some other bad wire. Two questions.
1. Am I just masking a unknown problem by useing the 12v?
2. What are your thoughts on just converting to 12v for good? The tractor is for working, so I don't care too much about keeping it original.
Thanks alot for any advice.
John C. (CA)
John C.(CA)
02-04-2000 01:22:47
 Re: Which way to go? in reply to John C.(CA), 02-02-2000 16:05:46
Hello All just an update.. Twopop- I at first used the coil without the resistor, and I have learned the errors of my ways... got a new coil today with a built in resistor.. I have pretty much made up my mind to go ahead and do a full 12v conversion with electronic ignition. As I said in my first post, This tractor will work for a living and I want the least amount of problems as possible. I'll save the restoration for the old 9N or something else..
Thanks to all for your help..
Great forum
John C.(ca)
STUMP PULLER
02-02-2000 16:21:47
YOU WILL LIKE THAT 12V. IF YOU WANT TO KEEP IT SIMPLE YOU COULD READJUST YOUR REG TO CHARGE AT 12V.
twopop
02-03-2000 17:37:46
 Re: Re: Which way to go? in reply to STUMP PULLER, 02-02-2000 16:21:47
DOES THE 12V COIL YOU PUT ON HAVE A BUILT IN RESISTER IN IT OR DID YOU PUT AN IN LINE RESISTER ON YOU WILL NEED ONE OR THE OTHER OR YOU WILL BURN POINTS CONSTANTLY
moye
02-04-2000 10:48:43
 Re: Re: Re: Which way to go? in reply to twopop, 02-03-2000 17:37:46
it is simple to put 12v points and condensor in this tractor. while you are at it, change to a 12v delco alternator and get rid of the gen. and reg. that is there now. If you think you might wish to restore to origional one day and quit working the tractor, save all the 6v stuff to put back on it. Just my two cents worth. Moye
