Re: Select-o-Speed Lock-up
Dan
09-08-1998 19:56:05
This is a real can of worms, you know?
The following information may help narrow things down a bit (I have been told that the Select-O-Speed is murder to work on). I am not a mechanic, but I do have this sort of info lying around. Comes in handy sometimes.
Symptom: Locks up in 3, 4, 7, 10, and R2. Malfunction: The one-way clutch locked up.
Symptom: Operates in overdrive ratios only. Malfunction: Band 1 is not releasing.
Symptom: Locks up in 1, 2, 3, 4, 9, 10, R1 and R2. Malfunction: Band 2 is not releasing.
Symptom: Locks up in 5, 6, 7, 8, 9 and 10. Malfunction: Band 3 is not releasing.
Symptom: Locks up in P, 1, 2, 3, 4, 5, 6, 7, 8 and goes to R1 in Neutral.
Malfunction: Clutch 1 is not releasing.
Symptom: Locks up in P, 1, 3, 5, 7, R1, R2 and goes to 2 in Neutral.
Malfunction: Clutch 2 is not releasing.
Symptom: Locks up in P, 2, 4, 6, 8, 9, 10, R1, R2, and goes to 1 in Neutral.
Malfunction: Clutch 3 is not releasing.
Hey, it's a start, anyway.
Dan
NAA60512
George
09-09-1998 04:21:09
 Re: Re: Select-o-Speed Lock-up in reply to Dan, 09-08-1998 19:56:05
: This is a real can of worms, you know?
: The following information may help narrow things down a bit (I have been told that the Select-O-Speed is murder to work on). I am not a mechanic, but I do have this sort of info lying around. Comes in handy sometimes.
: Symptom: Locks up in 3, 4, 7, 10, and R2. : Malfunction: The one-way clutch locked up.
: Symptom: Operates in overdrive ratios only. : Malfunction: Band 1 is not releasing.
: Symptom: Locks up in 1, 2, 3, 4, 9, 10, R1 and R2. : Malfunction: Band 2 is not releasing.
: Symptom: Locks up in 5, 6, 7, 8, 9 and 10. : Malfunction: Band 3 is not releasing.
: Symptom: Locks up in P, 1, 2, 3, 4, 5, 6, 7, 8 and goes to R1 in Neutral.
: Malfunction: Clutch 1 is not releasing.
: Symptom: Locks up in P, 1, 3, 5, 7, R1, R2 and goes to 2 in Neutral.
: Malfunction: Clutch 2 is not releasing.
: Symptom: Locks up in P, 2, 4, 6, 8, 9, 10, R1, R2, and goes to 1 in Neutral.
: Malfunction: Clutch 3 is not releasing.
: Hey, it's a start, anyway.
: Dan
: NAA60512
This could be major dollars.
Buford
09-12-1998 10:32:02
 Re: Re: Re: Select-o-Speed Lock-up in reply to George, 09-09-1998 04:21:09
:Question,these guys that have Ford select-o-speed :problems.Would it be too cost effective to replace it with a standard transmission???: This is a real can of worms, you know?
: : The following information may help narrow things down a bit (I have been told that the Select-O-Speed is murder to work on). I am not a mechanic, but I do have this sort of info lying around. Comes in handy sometimes.
: : Symptom: Locks up in 3, 4, 7, 10, and R2. : : Malfunction: The one-way clutch locked up.
: : Symptom: Operates in overdrive ratios only. : : Malfunction: Band 1 is not releasing.
: : Symptom: Locks up in 1, 2, 3, 4, 9, 10, R1 and R2. : : Malfunction: Band 2 is not releasing.
: : Symptom: Locks up in 5, 6, 7, 8, 9 and 10. : : Malfunction: Band 3 is not releasing.
: : Symptom: Locks up in P, 1, 2, 3, 4, 5, 6, 7, 8 and goes to R1 in Neutral.
: : Malfunction: Clutch 1 is not releasing.
: : Symptom: Locks up in P, 1, 3, 5, 7, R1, R2 and goes to 2 in Neutral.
: : Malfunction: Clutch 2 is not releasing.
: : Symptom: Locks up in P, 2, 4, 6, 8, 9, 10, R1, R2, and goes to 1 in Neutral.
: : Malfunction: Clutch 3 is not releasing.
: : Hey, it's a start, anyway.
: : Dan
: : NAA60512
: This could be major dollars.
