follow up
Jason5575
04-12-2008 12:12:37
Ok so I figured out how to get the wires out. I went ahead and hooked up the wires from the Pertronix as follows: black/white to coil negative, black to ignition switch wire coming from voltage regulator. It would not fire at all. There is a 3rd wire Pertronix has you hook up from the coil positive to the battery positive or chassis. I hooked that wire up to the bolt that holds the coil to the engine block. When I turn the switch on the wire stands up and sparks/smokes like crazy. Can't figure out what I am doing wrong?
My ignition switch is simply a flip switch on/off with a wire going from the voltage regulator to the switch and a wire going from the coil positive to the switch.
mark from the fort
04-12-2008 15:48:30
 Re: follow up in reply to Jason5575, 04-12-2008 12:12:37
I do not have such a system, however, most 6 volt systems are POSITIVE ground. Is it possible that you have your ground wire incorrect. On most 6 volters, the positive from the coil goes to the side of the distributer.
Would this help?
Mark
mark from the fort
04-12-2008 15:52:10
 Re: follow up in reply to mark from the fort, 04-12-2008 15:48:30
I forgot to ask, did you specifically request a petronix for a 6 volt positive ground system.?
I believe that they are different than the 12v. pos. ground systems.
Mark
Jason5575
04-12-2008 17:19:16
 Re: follow up in reply to mark from the fort, 04-12-2008 15:52:10
Thanks for the help. Yeah I got a system for the 6 volt positive ground. After some fishing around, I had one too many wires hooked up to the negative side of the coil. Once I removed the original wire from the ignition switch to the coil, the system fired and stopped sparking. Glad it was something that simple, yet feel silly missing it.
