TO-20 Pertronix install help
Jason5575
04-12-2008 10:14:31
Hello,
I am getting ready to install a Pertronix Ignitor on my 51 TO-20. It still has the original dist and is still a 6 volt positive ground system. I got the kit from this site. One question for those who have installed this, how did you get the wires routed out of the distributor? Jut eyeballing it I don't see a place to run the wires out. Any install tips or tricks I should know? Thanks.
Bob (Aust)
04-13-2008 13:56:32
 Re: follow up in reply to Jason5575, 04-12-2008 10:14:31
Takes 10 minutes to install in the Lucas distributor. Remove and replace the distributor top plate and connect to coil, taking care to ensure polarity is correct. I also purchased the Pertronix high voltage coil.
Bob (Aust)
04-12-2008 18:05:36
You are lucky you didn't fry the Igniter! There is a warning that reverse polarity will destroy the unit.
third party image
Pertnonix Igniter in the Lucas distributor of my TEA20.
You will be very pleased with the improvement in starting and running.
Bob in Oz
mark from the fort
04-13-2008 10:31:54
 Re: follow up in reply to Bob (Aust), 04-12-2008 18:05:36
Pretty neat, I see that the red and black from inside dist. go to + and - on coil.
Where there any other modification?
I assume you just removed the old wiring at these locations?
Just asking for curiosity sakes.
I've been LEANIN""" real hard towards one for my 6 volter. She actually needs a rebuild, but am trying to milk her for another season of rototilling.
Nice pic. Mark
Jason5575
04-12-2008 12:12:37
Ok so I figured out how to get the wires out. I went ahead and hooked up the wires from the Pertronix as follows: black/white to coil negative, black to ignition switch wire coming from voltage regulator. It would not fire at all. There is a 3rd wire Pertronix has you hook up from the coil positive to the battery positive or chassis. I hooked that wire up to the bolt that holds the coil to the engine block. When I turn the switch on the wire stands up and sparks/smokes like crazy. Can't figure out what I am doing wrong?
My ignition switch is simply a flip switch on/off with a wire going from the voltage regulator to the switch and a wire going from the coil positive to the switch.
mark from the fort
04-12-2008 15:48:30
 Re: follow up in reply to Jason5575, 04-12-2008 12:12:37
I do not have such a system, however, most 6 volt systems are POSITIVE ground. Is it possible that you have your ground wire incorrect. On most 6 volters, the positive from the coil goes to the side of the distributer.
Would this help?
Mark
mark from the fort
04-12-2008 15:52:10
 Re: follow up in reply to mark from the fort, 04-12-2008 15:48:30
I forgot to ask, did you specifically request a petronix for a 6 volt positive ground system.?
I believe that they are different than the 12v. pos. ground systems.
Mark
Jason5575
04-12-2008 17:19:16
 Re: follow up in reply to mark from the fort, 04-12-2008 15:52:10
Thanks for the help. Yeah I got a system for the 6 volt positive ground. After some fishing around, I had one too many wires hooked up to the negative side of the coil. Once I removed the original wire from the ignition switch to the coil, the system fired and stopped sparking. Glad it was something that simple, yet feel silly missing it.
