LOWER LIFT ARM BOLT
fergi49
04-10-2008 09:53:40
I WAS WONDERING IF ANYONE KNOWS ANYTHING ABOUT THE LOWER LIFT ARM BOLTS. IF THEY SCREW IN OR IF THEY HAVE A NUT ON THE INSIDE OF THE REAR END HOUSING. WHAT MIGHT BE THE REPLACEMENT PROCESS. THANKS!
Ohio Ed
04-11-2008 20:09:11
 Re: LOWER LIFT ARM BOLT in reply to fergi49, 04-10-2008 09:53:40
I recently replaced one on my TO 35. Its easier than it sounds. Remove the tire and fender. Drain the Gear Oil. Un hook the brake linkage and remove the nuts that hold the axle housing. I used an engine crane to hold the axle houseing. The pin is held on by a nylon lock nut. A new pin was just a few bucks at the dealer and the gasket was $1.00. I've seen the pins on ebay.
marlowe
04-10-2008 15:09:32
also they have a taper fit so if it's lose you better change it fast so you don't mess the hole up
Jeff-oh
04-10-2008 11:24:16
There is a nut on the inside. If the pin is loose you have to take the axel housing off to get at it.
This has been discussed and procedures presented. I'd suggest doing an archive search.
Jeff-oh
04-10-2008 11:28:51
 Re: LOWER LIFT ARM BOLT in reply to Jeff-oh, 04-10-2008 11:24:16
heres a link about this issue.
