diff in TO 20 and TO 30
Don Reavis
10-19-2006 07:39:34
my ser # above steering wheel is TO-3555 . no oil filter on side of eng . i think its in the oil pan .also the air intak is not on the dash like my orher tractor . tag on eng only has #104724 on it dont say Z120 Z129 ect. block casting says Z12 then a # ground off then A300. tranny housing cast # is HF TO 7006 i can send pics if needed thanks Don Reavis Yadkinville NC email [email protected]
Scott Morrow
10-20-2006 16:50:26
 Re: diff in TO 20 and TO 30 in reply to Don Reavis , 10-19-2006 07:39:34
Don I have a to20 with Z12 and the enbossing ground off with a 0 stamped in making it read z120.My block also is cast for the outside oil filter and the to30 generator bracket. I was told that the old guy who owned it put in a factory short block. I asked my old ferguson dealer and he said that massey was not making the to20 blocks anymore at the time and sent the customer a to30 block but didn't drill for the outside oil filter so they could reuse the to20 oil pan. I had to put a new head on mine it had a 30 bore so I put on a 30 head and carb check to see it your block has the oil filter casting on it. Scott
phil(va)
10-19-2006 08:07:47
Are you asking a question? pretty obvious you have a TO-20. Was that the question?
Don Reavis
10-19-2006 08:47:44
 Re: diff in TO 20 and TO 30 in reply to phil(va), 10-19-2006 08:07:47
whats the diff between a 20 and a 30 how do u tell by looking
Jim in OH
10-19-2006 09:03:30
 Re: diff in TO 20 and TO 30 in reply to Don Reavis , 10-19-2006 08:47:44
Here is a thread that discusses some of these.. Jim
don reavis
10-19-2006 09:26:47
 Re: diff in TO 20 and TO 30 in reply to Jim in OH, 10-19-2006 09:03:30
thanks a bunch Yalllll ll
