Re:FORGET THE LEAD ADDITIVE!!!
Gerald J.
10-01-2006 18:07:11
It won't hurt the engine to run without lead additive for the next 5000 hours or so. That's not what is killing it.
Actually lead additive may foul the plugs far faster.
Running for ten minutes, then quitting is characteristic of two or three different problems. If the gas tank cap doesn't vent it will suck fuel for about that long and then run out. The other problem that does that is a failing ignition coil that heats up and shorts a turn, then cools off and runs again. Rarely a condenser will do that also. You can check for gas tank vent by loosening the cap when it stops and listen for the air rushing in to fill the vacuum. You can check for coil or condenser by checking for spark just after it quits running.
Gerald J.
