No safety feature???
mike2
06-24-2006 18:43:34
Can"t help you with your problem directly, but wouldn"t ya think there would be a specific weak piece, such as a sheer pin for example, that would indeed sheer off prior to causing more extensive damage? Maybe somebody eliminated this on your tractor? Sometimes a welder fixes stuff which is not intended to be fixed.
How about other PTO drivin impliments? Isin"t there any safety feature I described above built into them? Reason I am asking, is I never really used the pto output on my tractor yet and where I intend to brush hog, I have many rocks.
John (UK)
06-25-2006 06:49:53
 Re: No safety feature??? in reply to mike2, 06-24-2006 18:43:34
If there are a lot of rocks as you say you can't set the mower too low, it is made for cutting grass only and continually hitting rocks will seriously damage it and possibly the tractor too. It wont matter if you have a clutch fitted or not, the momentum of the mower blades at cutting speed when it strikes a rock can cause all kinds of problems. If you want to cut low you have to clear the rocks. Not good news and probably not welcome either but it is true.
