fixed it!
Boutwah
06-16-2006 18:42:02
Came loose today with very little effort. Thanks
Jim in OH
06-17-2006 11:27:43
 Re: fixed it! in reply to Boutwah, 06-16-2006 18:42:02
So you mind explaining what method worked? Jim
boutwah
06-17-2006 15:24:45
 Re: fixed it! in reply to Jim in OH, 06-17-2006 11:27:43
I put a good load behind the tractor and got it into gear while it was running. I had tried this several times with no luck before. I never was able to get it to go into 4th gear, but when it finally came loose it wasn't even moving. I had just killed it trying to free it, restarted the tractor and put it back into gear, without even lurching forward it popped loose.
Jim in OH
06-17-2006 15:51:52
 Re: fixed it! in reply to boutwah, 06-17-2006 15:24:45
Good deal! Thanks for sharing that... I am not surprised that you couldn't get it into 4th while running... I was refering to towing it from a complete stop (engine not running)... This method would not have been better than what you did... if you were able to stall the engine under full throttle, that is about as good as you can do and it doesn't matter what gear as long as you can get a full engine load... Jim
