thanks..and couple more questions
George NW MI
04-05-2005 07:41:39
I did disconnect the gauge and then started the engine, no oil came out of the engine block where the oil pressure line hooks up.
I also attached could also blow air back through this galley, so I concluded it was not a gauge problem.
I did drop the oil pan. Everything looks like it is connectec, but I will check this pickup line as you suggest.
I have not checked to see if the oil pump gear turns when the engine turns...but would this give me any useful information? For example, if the pump failed would that gear still turn when the engine turned?
Thanks very much for your help
gshadel
04-05-2005 12:44:32
 Re: thanks..and couple more questions in reply to George NW MI, 04-05-2005 07:41:39
George,
that oil pump gear is just pressed onto the oil pump shaft with a little set screw to hold it in place. I imagine it is possible that the gear could spin free on the oil pump shaft if the set screw has fallen out or something got into the pump to lock it up. If the suction line looks to have a good seal on each end, then you might want to go ahead and pull your pump to check it out.
Several places also sell an oil pump rebuild tool, in addition to the pump rebuild kit. That tools main purpose is to make it easier to press the aluminum drive gear onto the oil pump shaft straight, and help you drill the set screw hole. I was able to do the rebuild without that tool, although I'm sure that tool would have made it easier. I used a socket and mallet to carefully tap the new gear onto the pump shaft, and had to use a drill press to drill the set screw hole, it is really hard to do with a handheld drill because the bit wants to run off into the soft aluminum instead of cutting the steel shaft, you'll see what I mean when you get into it.
