oil pump change...and rebuilt availability
GW in Michigan
04-04-2005 10:16:55
I lost oil pressure on my TO-20. I dropped the oil pan, everything looks to be in place. How hard is it to replace the oil pump? From the manual and visual inspection, it looks like it is just held in by some bolts at the bottom. Is that right, or is there more to it/
Anyone know where a rebuilt pump can be purchased?
gshadel
04-05-2005 05:56:21
 Re: oil pump change...and rebuilt availability in reply to GW in Michigan, 04-04-2005 10:16:55
GW, your oil pump is bolted on the front crank bearing cap. Two bolts, and remove the suction line, and it's off. Rebuild kits readily available from this web site and many others for ~$40 or so. The pump rebuild is easy, the only hard part is getting that aluminum gear pressed on the shaft straight and drilling for the set screw. But can be done with regular hand tools.
If you had a sudden pressure loss, rather than a gradual decline, it might not be the pump itself. I'd check your suction line first to make sure it is tight and has a good seal, check your oil pressure guage to make sure it doesn't have a clog in it, and pull the cotter pin on the spring loaded relief valve on the oil pump, and pull the plunger to make sure it isn't stuck open with a piece of crud. If all that checks out, then spending $$, and time on a pump rebuild is probably the next step.
George NW MI
04-05-2005 07:41:39
 thanks..and couple more questions in reply to gshadel, 04-05-2005 05:56:21
I did disconnect the gauge and then started the engine, no oil came out of the engine block where the oil pressure line hooks up.
I also attached could also blow air back through this galley, so I concluded it was not a gauge problem.
I did drop the oil pan. Everything looks like it is connectec, but I will check this pickup line as you suggest.
I have not checked to see if the oil pump gear turns when the engine turns...but would this give me any useful information? For example, if the pump failed would that gear still turn when the engine turned?
Thanks very much for your help
gshadel
04-05-2005 12:44:32
 Re: thanks..and couple more questions in reply to George NW MI, 04-05-2005 07:41:39
George,
that oil pump gear is just pressed onto the oil pump shaft with a little set screw to hold it in place. I imagine it is possible that the gear could spin free on the oil pump shaft if the set screw has fallen out or something got into the pump to lock it up. If the suction line looks to have a good seal on each end, then you might want to go ahead and pull your pump to check it out.
Several places also sell an oil pump rebuild tool, in addition to the pump rebuild kit. That tools main purpose is to make it easier to press the aluminum drive gear onto the oil pump shaft straight, and help you drill the set screw hole. I was able to do the rebuild without that tool, although I'm sure that tool would have made it easier. I used a socket and mallet to carefully tap the new gear onto the pump shaft, and had to use a drill press to drill the set screw hole, it is really hard to do with a handheld drill because the bit wants to run off into the soft aluminum instead of cutting the steel shaft, you'll see what I mean when you get into it.
Barry from Stirling
04-04-2005 11:56:49
Afternoon GW
Could you explain " Lost Oil Pressure" Did you loose it completely or did it just drop? The reason I ask is because when I start my TEA-2085 the oil presure will be between 55 & 60 lbs presure, according to the guage. After about 1 hour the presure will drop off quite a bit , down to around 20 lbs presure. From all the comments in here this is quite normal. I just make sure I change my oil in the spring and fall. Regards Barry
George in NW MI
04-05-2005 17:40:24
 Re: oil pump change...and rebuilt availability in reply to Barry from Stirling, 04-04-2005 11:56:49
Barry, yours sounds fine to me.
When I say I lost pressure, I mean that it went from 20 psi to 0 quickly. Mine consistently ran at 20 psi hot or cold.
