Re: 51 M Has Puny-Weak Spark
Doug in OR
09-27-2002 08:55:12
Do you have a good, solid voltage at the coil? A poor connection at any end of the wire feeding the coil could cause a significant voltage drop.
Also, check the spark right from the coil. If it is nice and blue, your distributor cap could be defective or dirty.
Doug in OR
09-27-2002 10:46:48
 Re: Re: 51 M Has Puny-Weak Spark in reply to Doug in OR, 09-27-2002 08:55:12
I might also add... check the ground inside your distributor. If the points aren't getting a good ground, you won't get a good current flow through the coil.
Bob M - good advice!
09-27-2002 14:42:26
 Re: Re: Re: 51 M Has Puny-Weak Spark in reply to Doug in OR, 09-27-2002 10:46:48
Check also to make sure the condenser has a good, clean ground inside the distributor. Also check if someone stuck resistor (aka "RF surpression") plug wires on the tractor. If they did, throw 'em out and replace with good old solid copper wires!
Tom
09-27-2002 17:02:58
 Re: Re: Re: Re: 51 M Has Puny-Weak Spark in reply to Bob M - good advice!, 09-27-2002 14:42:26
Also check the grommets or insulators on your distributor were there is connections or terminals. I had this on my M, resulting in a weak spark. It drove me nuts for several weeks before we tracked it down. Check these using an ohm meter looking for voltage leakage between the terminal and the distributor body.
