Order Farmall Cub Parts Online
Re: Cub Problems
Bob
09-26-2002 15:40:25
JR, you throwout bearing is worn out. It is made out of graphite and when the leading edge wears down the bearing carrier comes in contact with the clutch fingers. As far as you stalling, remove the brass plug on the bowl of the carberator to see if you have good flow of gas. If the coil is bad it could be dropping the spark when it heats up. Bates Corp is now making a replacement TO bearing with a sealed rollar bearing. I will be replacing mine soon since I have the same clutch noise.
