Re: Super M bearing
Diesel Don
08-22-2002 20:29:18
If there is an industrial supply near you,try them.Applied Industrial Supply,Motion Inc,Wisconsin Bearing are three that come to mind.Look for a number stamped into either the inner or outer race of the bearing and give them the number.If it is a standard bearing,they will be able to match it.If the manufacture is stamped somewhere on the bearing,that will also help.If these guys can't help,my advice would be to go back to IH.I know their parts are expensive,but I have yet to go wrong with thier parts.
RPM
08-23-2002 07:03:45
 Re: Re: Super M bearing in reply to Diesel Don, 08-22-2002 20:29:18
If you dont want to use the tractor for heavy duty work you could use a cheaper bearing, however the correct bearing has a grade code of max, which means in bearing talk it is loaded with maximum amout of balls they can get in space allowed, IH Part ST218A about $70. Its your call, you get what you pay for.
