Re: 450 power steering question
jmyt_47
06-24-2002 07:28:28
If it's the factory powersteering, the priority valve is in the bank of hydraulic spool valves under the dash sheetmetal of your 450. It should have a hydraulic line running from it to the powersteering. Its the square block on the left in between the gas tank and hydraulics. Some disassembly required. Sounds like it needs a good cleaning, o-orings, and maybe a check valve spring.
