Re: Felt rear main seal. Install dry or oil soaked?
Ace Schrunk
06-07-2002 10:09:24
Install dry into holder or you will not get it in there and stuf it all in there don't cut some off then a little oil befote instaling on block
Avalon
06-07-2002 10:38:57
 Re: Re: Felt rear main seal. Install dry or oil soaked? in reply to Ace Schrunk, 06-07-2002 10:09:24
I cut some off mine when installing and haven't started engine yet. You're telling me this is gonna leak? $%#@#! Anybody cut them off some and had 'em not leak? Looks like I may be in for a do-over huh?!
Paul Shuler
06-08-2002 07:22:23
 Re: Re: Re: Felt rear main seal. Install dry or oil soaked? in reply to Avalon, 06-07-2002 10:38:57
When you say you cut some off do you mean in the length of the felt or the thickness of the felt?I just put one in my Super C and on the thickness it stuck up over the top of the groove maybe an 1/8 of an inch. But on length it was way to long and the instructions that came with it said it might be and just to cut off the ends.
Avalon
06-09-2002 08:47:38
 Re: Re: Re: Re: Felt rear main seal. Install dry or oil soaked? in reply to Paul Shuler, 06-08-2002 07:22:23
I just cut off a little on the ends not the width. I still had to force it down over the crank and bolt it up.
Mike S
06-07-2002 21:23:43
I did my Faramall H and 300 I had to cut some off there was no way I could get it all in there. The felt seal came from a Felpro gasket set. No leaks at all.
I second that.
06-07-2002 10:18:39
Do not cut off "just a little" because someone did not make it the right size. Don't ask why I know. (The seeping should tell) Force it in the best way you can. G.
