Re: What type of undercoat paint to use
Lyle
08-12-1999 18:56:36
I always use a red primer, have had bad luck with gray when I overhauld a #37 disk. You should always try to use same brand undercoat and top coat. If you know that 2 differant brands will work ok together,go for it. Good luck, Lyle
Farmall Gray
08-15-1999 19:02:48
 Re: Re: What type of undercoat paint to use in reply to Lyle, 08-12-1999 18:56:36
I have always had trouble using a primer of similar color to the paint. I use a contrasting color so that I can more easily see what spots I missed. And it is easy to miss some spots on a tractor. I guess some could argue that if you did miss some spots it would not be as noticable with a similar color primer. If you are priming the whole tractor it doesn't matter what color primer you use, but if you are only priming spots use similar colored primer so that is easier to cover.
