Re: thermastat
Steven@nd
03-08-2002 09:41:47
The less the use the more important the thermostat! Studies have shown that an engine running less than 180 degrees F coolant temp wears much quicker. If the engine is cold the fuel doesn't burn and it washes the oil off of the cylinder walls. I recommend putting a 180 thermostat in right away.
Steven
mike
03-08-2002 09:51:11
 Re: Re: thermastat in reply to Steven@nd, 03-08-2002 09:41:47
i assume their is no thermastat, bacause upon cold starting i checked to see if the radiator fluid was turbulent and it was.either stuck open or not their i guess.should i open the housing and check.
