Thermastat
mike
03-08-2002 09:37:31
i dont beleive the thermostat is in my new used tractor. is this a problem,and can i still run machine,it gets very little use maybe 10 hrs a week.
Red Dave
03-08-2002 10:44:29
 Re: thermastat in reply to mike, 03-08-2002 09:37:31
What model tractor?
A's, B's, BN's, & early C's didn't have thermostats or water pumps. They use the thermosyphon system of cooling.
H's, M's & some others had thermostats & water pumps.
What do you have?
mike
03-08-2002 11:26:16
 Re: Re: thermastat in reply to Red Dave, 03-08-2002 10:44:29
i have a 1969 6 cylinder diesel,do i have a thermostat.i think its a d236 motor
RPM
03-09-2002 09:17:54
 Re: Re: Re: thermastat in reply to mike, 03-08-2002 11:26:16
Thermostat is 313942R92, 180 degreee, about $15 at CNH dealer, if engine is a D236 glow plug start diesel, should be in engine year around, only reason to remove it is if heating problem and thermostat is suspect of restricting coolant flow.
Red Dave
03-08-2002 11:49:47
Not familiar with that particular engine, but I would think it should have one. It's important to operate an engine at the proper temperature. I'd get one as soon as possible. You may want to get an operator's and a service manual too while you are at it.
Steven@nd
03-08-2002 09:41:47
The less the use the more important the thermostat! Studies have shown that an engine running less than 180 degrees F coolant temp wears much quicker. If the engine is cold the fuel doesn't burn and it washes the oil off of the cylinder walls. I recommend putting a 180 thermostat in right away.
Steven
mike
03-08-2002 09:51:11
 Re: Re: thermastat in reply to Steven@nd, 03-08-2002 09:41:47
i assume their is no thermastat, bacause upon cold starting i checked to see if the radiator fluid was turbulent and it was.either stuck open or not their i guess.should i open the housing and check.
