Re: M oil pump and cam removal
C.Fitz
04-06-1999 23:33:36
The oil pump has to be taken off first by the 2 mounting bolts and it should pull down as it unmeshes with the cam-shaft gear. To get the camshaft out you have to take off the front timing cover, which involves a whole lot of work. the radiator needs tocome off, the front crankshaft pulley needs off. Then unbolt front timing cover.You'll also need to pull rocker arm ass.; pull lifters out, then take that tappet plate off the side of the block and lift your tappets out from off the cam-shaft. Then you can unbolt the cam-shaft timing gear bolts and the cam-shaft should pull out with the gear attached toward the front of the tractor. I might of forgot a few things but that should get you in the ball-park. Have fun.
